Good? should I go WC?
slaya
Abit NF7-S Rev 2.0 already own
AMD Barton 2500+ Retail $90.00 http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-379&depa=1
2x Corsair XMS DDR400 512mb $210.00 http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-1
WS 80gb 8mb cache $70.00 http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101206
Samsung 16x DVD Rom $29.00 http://www.newegg.com/app/ViewProductDesc.asp?description=27-151-039&catalog=55&depa=1
CoolMax CX-350 350watt $37.00 http://www.newegg.com/app/ViewProductDesc.asp?description=17-159-022&catalog=58&depa=1
Thermalright SP 97 $46.00 http://www.jab-tech.com/customer/product.php?productid=2058&cat=&page=
Total: $482.00
Budget: $570.00
Those are the parts I am planning on purchasing, are they good for OCing?
I am going to OC and I would like to know if I should use that heatsink I have listed there, or save that $46.00 and add it to the $88.00 I have left over from my parts and get a WC setup, because I want a really quiet PC.
orrr.. should i spend that extra money and get better parts?!?!
you should get the ThermalTake Silent Boost
its rated at 21 dBa and it works very nice, i have one and i can safely recommend it :D
What video card are you getting? Also, if you can find a Zalman or Fortron PSU, you should get those over the CoolMax.
I am probably going to stick with my GeForce4 Ti4200, and see how it holds up, if not I will upgrade to something ~$160
Oh and sorry for not mentioning it but, I am going to be using my Antec 350watt PSU which I will be ripping out of my current system and replacing it with the cheaper PSU I am going to be purchasing. A lot of people seem to like Forton, I guess I will use that instead, thanks.
