good SFF makers other than shuttle
claremont
Hi,
I am looking to buy a lower end (1000-1500$) SFF comp. I don't really have the time or knowledge to build my own so I am just going to get it premade. What are some good makers other than shuttle? I am not really that game intensive, but the comp has to have 2GB of ram and has a vid card that has two DVI outputs.
Thank you
claremont said:
Hi,
Thank you
You could try the "Hornet" from Monarch.com. You pick the components and they will build it for you. Falcon Northwest (Frag Box2) and Performance-Pc (Qmicra) are good also but they are way over your budget.
If you want a really good SFF, build your own or get the Fragbox. The Hornet is awesome too, but I don't really like the way it looks.
