What will you be running on it? To be any help, we'll need to know what video card, CPU, and number of drives you'll be using. It'd also be helpful to know what sort of case you're putting it in.
I bought this for 99$ on newegg with free shipping....EVGA SuperNOVA 650 P2 220-P2-0650-X1 80+ PLATINUM 650W Fully Modular EVGA ECO Mode Includes FREE Power On Self Tester Power Supply - Newegg.com for 99$ going into a one video card system, I think it was a good choice.
Thanks,
But, I was looking for something more robust like 750+
You need to rethink that. That's massive overkill for the system described. You'd have to try really hard to get close even to 300W.
Seasonic SSR-450RM, $80. If you try you can probably find it on sale somewhere.
Thanks,
So even if I decide to bump it up a little bit the clocks 650W will be enough?
Thanks
Robustness has nothing to do with power rating.
6600k- 120 watts max.
GTX 1070- 200 watts max.
Everything else- 50 watts.
Get a good 550 watt PSU. I would recommend the EVGA G2.
It's crazy how uneducated I was on the state of what's really needed for power in desktop pcs. I thought everything needed so much power. I even looked down at anything 650 and less.
I got schooled!
Thanks![]()
