Good PSU for this rig?
InorganicMatter
ASUS A8N-E
Athlon 64 X2 4400+
Geforce 7800GT
1GB Corsair
2x 160GB SATA Drive
DVD+RW
Light overclocking, and I'm pretty sure that board needs a 24-pin connector. Budget is "reasonable" :p
Well that would be 18.8 amps on the 12v alone for the videocard. I will see what the numbers over all look like. How many case fans etc also?
sac_tagg said:
Yeah, about 2 80mm case fans, and one 92mm fan (XP90). Budget is maybe $150?
In that case start hitting the FS/FT forum and hope you pull an n64man_120 and get a PC Power and Cooling 510 for 140 used otherwise shop these PSU around for a better price:
http://www.newegg.com/Product/Product.asp?Item=N82E16817194001
http://www.newegg.com/Product/Product.asp?Item=N82E16817151025
http://www.newegg.com/Product/Product.asp?Item=N82E16817103714 Haha tossed that one in just for fun.........although...........
We are talking worse case so a few of these others will probably cut it also..........but until we know the exact figures on those next gen videocards it is all guess work. Hopefully someone will dump the numbers we need monday, who knows a white rabbitt might come out of the hat:
http://www.newegg.com/Product/Product.asp?Item=N82E16817103458
http://www.newegg.com/Product/Product.asp?Item=N82E16817103933
http://www.newegg.com/Product/Product.asp?Item=N82E16817151024
