After a week of reading I'm almost decided on my new build. I'm just not sure on the following parts for clocking...
Motherboard: Asus P5N-E
Memory: GeIL 2GB (2x1GB) PC6400C5 800MHz Value DDR2 Dual Channel Kit -
800MHz RAM Speed, CAS 5-5-5-15 Timings, 1.8-1.9v VDIMM, Lifetime Warranty with GeIL.
CPU: E6300 (maybe E4300)
Cooler: Tuniq Tower 120 CPU Cooler
I think the motherboard and cooler are adequate. I want to get an SLI mobo if possible, and this seemed a good option.
I want to take the CPU above 3Ghz, if the 6300/4300 and reach that. The higher the better, but ill be happy with 3Ghz. Is this likey with this setup? Im not sure if the ram is up to the task, would I better with;
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 - 800MHz RAM Speed, CAS 4-4-4-15 Timings, 1.8-2.1v VDIMM, Lifetime Warranty with OCZ.
or
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit - 800MHz RAM Speed, CAS 4-4-4-12 Timings, 1.9-2.3v VDIMM, Lifetime Warranty with GeIL.
Ta
or
Ta
