I need to purchase a router that I'll be using for a server. I read somewhere I while back about some routers that could be modded with firmware and achieve 2000-4000 connections. This is for home use and just temporary for about a month so it doesn't need to be top of line. I just need max connections.
2000-4000 would be about perfect but of course I wouldn't object to more. I read the main router thread and all the links very helpful. It seems all of them are factory limited to 200 threads.
Which routers can I buy for under 100 bucks and that are compatible with which firmware to achieve these goals?
Wireless does not matter in fact I would prefer non-wireless.
Please help,
Thanks!
Also if I set up the router to handle 4000 threads. What should I set my TCP Half Open Limit to? Would that be 4000 as well? Or which other settings in the OS should I edit? I'll be using windows server os.
Please help,
Thanks!
