Good mobo / CPU / Mem for a web backup server?
Gutspiller
I'm creating a backup server that is going to have a SATA RAID with two 1TB drives in RAID and two 1TB mirroring that RAID.
The server is going to be grabbing backups daily, weekly, and monthly. I may opt to do another backup between daily and weekly though just in case I need the backup, that could be quite a bit of web data lost if I had to use the weekly.
I'm looking for an something that has at least 4 SATA connections, but maybe more for upgrading later.
I don't think I need a super fast processor in this case, but I've never built a server before. I do know I want it to be Intel and not AMD.
1. Can somebody recommend a motherboard / CPU and memory for my remote web backup server that will last so I don't have to upgrade for a good while?
2. Is a mobo with SATA RAID onboard OK or do people recommend a SATA RAID add-in card?
3. I'm planning on 2TB backup and 2TB mirroring that backup. Is that an OK plan or would people recommend something better? I'm having second thoughts on if the mirroring is needed or not. I'm wondering if I should just do a 4TB RAID so that the space lasts longer.
4. This server shouldn't need "speedy" memory to do it's job right? I mean just some regular memory that fits the board should be OK right?
5. Any other suggestions you can give me would be appreciated, I've never built a backup server or a server at all so I'm a little lost on what components for the entire machine I should be picking.
I'm having to work with my host to help me setup my web servers to send the backups to this server and I'd like my backup server to be powerful enough that I don't have to re-setup the whole thing for a good while.
Thanks for your help!
"Two 1TB drives in RAID"
What kind of raid?
"and two 1TB mirroring that RAID"
Raid 1.
You only need raid 1 if you feel like a drive is going to fail. Maybe you should be asking what kind of software is going to do any of this.
I'm not sure how critical this data is, but a backup to a single 1TB might be enough (maybe 2 in raid1 if you feel like a drive could fail).
Raid 10 also might be an option, a mirrored copy of striped drives (if you want performance and redundancy).
There is also Raid 5, but I am confused to this day on how it works.
The exact words from our host on what they had recommend:
"You will need raid 5 or 10 setup. If you provide shell or ftp access, we can enable backup on all 3 servers to be transferred to your backup server."
Generally speaking, a back up server does not need to be anything special. Now, I don't know what type of software you are going to be running, or OS your putting on. But, if the purpose of this device is purely back up, then you don't need much system resource at all. You could even save yourself a little money if you want and buy a NAS that supports raid backup.
Also, do you have a budget for this? Knowing more about the software, OS, and budget your going to use will help narrow the decision down.
I was told it's best to use the same OS that's on the webservers which is CentOS (release 5.2 (Final) on one server and 5.0 final on the other two). I believe people are telling me that rsync will be the way to go for backing up the data to this backup server and that's why it was recommended of using the same OS that's on the webservers due to capital letters in filenames.
Now that I have these mentioned, can somebody throw out what type of hardware I'm going to need? I'm fairly set on the 4TB of storage with 2TB as the backup, and the other 2TB mirroring that.
If somebody knows of a better way to do this like a pre-built machine that is easier to manage for somebody new to this all or that would perhaps be easier to add storage to later, then I am open to suggestions. If nothing else though I would like to know what other hardware I am going to need if I continue to go with the plan of building it myself piece by piece.
If you use raid5, you can use three 1TB drives, two striped and one backup, so if one fails the data can be remade onto the two drives that still function. You might want to wikipedia raid5 and raid10
You will need a dedicated raid card for anything like raid 5 or 10.
