Good memory for gaming?
twitchy10
I own an e1505 and do some gaming on it.
I would like to get 2gb of memory for it, but I was wondering if there is a good brand of memory to get that would help out with the gaming
Thanks
Unless u OC mem is mem. Just make sure you get a reputable company.
Corsair value is the cheapest. Crucial is great, G.Skill, adn a few others.
I personally wouldnt buy it. I know ppl have bougth it and done great.
What is your budget?
Is that an emachine PC?
Can you OC? Do you have good bios options?
at the moment there is no budget because i don't have anything to spend on it, i'm just trying to get options for when i have the cash
no it's a dell e1505
i don't know about the OC never tried plus I don't know how, some guidance would be great though
I just went into BIOS and apparently i can't change anything with the memory it is just displayed information that i can't change
So 533 and 667 mhz ram is the same? And 4-4-4-12 or 5-5-5-15 timings are the same too? :rolleyes:
Whoa.... I 4got Dell = Inte = DDR2.... you sure you have DDR2?
667 is faster than 533 and you usually want lower timings.
4 4 4 is better than 5 5 5.
Since you can't overclock on a dell I would get the tightest timings... I'm not sure what mobo is in there so I'm not 100% though....
is the cas latency the same as the timing?
