MurphysLaww
- Feb 12, 2007
I have a silverstone HTPC chassis that I'm using the silverstone passive cpu nano-heat pipe thing (you can mount 60mm fans to the upper cooling fins, but I have two 80mm fans pulling air out of the chassis about an inch behind it) that is doing an OK job now that I have a 120mm fan pulling the chassis heat out of the top.
The setup I have is fine for a small overclock, like the P5NE bumped to a 300ish FSB. The temps at idle are in the mid to high 40s and still less than 60c at load.
I had this setup in an upright server chassis with the FSB bumped to 400mhz, running the ram at 800, and had about the same temps, but the HTPC sits in a closed cabinet with only a 4in gap at the top back for fresh air. Right now I've got the 400/800 back on and I'm running at the mid to high 50s at idle and mid 60s at load.
Can the C2D sustain those temps?
I have considered the Coolit contained cooling system as the clearance wouldn't be an issue then. Are there any GOOD lower profile fans that might get me through better until I try to liquid cool it?
*Edit* Just broke 10,000 in 3DMark06 for the first time. SLi for the Masses!!!, and with two BFG 7950gt cards, It only cost me less than $400.00 !!!
