Good low end video card?
The 7600gs is probably a nice choice for that system, but it would probably be more cost efficient to update your system to a PCI-E solution soon. For example, a 7600gs AGP is $95, but the equivalent PCI-E 7600gs is a bit cheaper at $75. Just a thought...
Could spend $20 or so more and get a X1950 Pro or GT that'd play near to everything that system will allow until you decide to do a new full build. It would be considerably more powerful than a 7600GS. There are occasionally even X1950 Pro's that come in under $100 after rebates. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102093 $120 after MIR. More than you were looking to spend, I realize, but I think it'd last you longer.
Unless only the video card is upgraded it might be a major upgrade. That proc looks to be a socket A Barton core and unless I'm mistaken there aren't any PCI-E motherboard in socket A. So the OP will need to upgrade the motherboard, processor, video card, and memory to switch to PCI-E. In AGP the 7600GS is going to probably be the best option under $100 if a big upgrade $$$ is not desired now.
Watch the FS/FT forum for a week or so. You should be able to pick up an X1950 AGP for under $100 used, and Sapphire (which most ATI cards tend to be) doesn't require registration, so it might still be under warranty, even. The X1950 is /considerably/ faster than all the other cards you're looking at.
well i went ahead and picked up the 7600GS and 2x512MB of corsair valueselect ram.. hopefully my pc will last me a few more years till my next build
If internet surfing and golf games are all you are doing, it might very well.
