good lcd for computer moniter and xbox 360
Alexdude777
hey, i'm looking for a new moniter that would run a PC pretty sweet and still play xbox 360. at first i thought of getting the 2405 because 24" has a wow factor, but i heard that it doesn't display hdtv! so is there a nice moniter in the 21-24 inch area that isn't too expensive, runs xbox 360, and a computer?
I'm in the same boat, see this thread I started:
http://www.hardforum.com/showthread.php?t=1002965
I've been surfing around a bunch of forums and I'd have to say the answer right now is "no", there isn't a decent affordable widescreen LCD 21-24" that doesn't have problems. The Dell 2405 apparently can't do true HD and the smaller Dell 2005 has tremendous backlight bleeding problems. Other monitors like Viewsonic won't scale an image to fit the monitor. The Gateway also has a list of problems. The only good option seems to be a Samsung model that costs roughly $1000 and that defeats the whole purpose of the Xbox 360 being an affordable gaming machine.
To compound the issue, the newer model LCD monitors coming out soon are apparently going to do away with component inputs in order to protect HD content from piracy. This means you will have to use the Microsoft VGA cable to hook up your Xbox 360 to the monitor, and if you've seen the VGA cable in action (I have), then you know it severely washes out color vibrancy.
The only possible solution at this point I can see is this device:
http://www.vdigi.com/
- where they sell the VD-Z3 which will accept 720p component inputs from any source and then transcode them to 720p output via VGA. I would think that might hook up to one of the Dells just fine and perhaps get around the no-HD problem. Keep checking my thread where "Tiny" says he will test the VD-Z3 with an Xbox 360 as soon as his comes back from repairs:
i have a 2005fpw, and its awesome with the vga cable, yes people complain about backlight bleeding but i mean honestly come on who sits looking at a black screen all day complaining about the backlight bleeding, mine has some bleeding and is noticible only on a pure black screen, if you are doing anything else you dont even know its there, i say go with the 2005fpw
Well, is it possible to get a nice CRT moniter that will work on my computer nicely, and still work on xbox 360 nicely?
Sure, there are probably lots of CRTs out there. Affordable too.
Just keep in mind that to use it with the Xbox 360, you'll need the VGA cable... and the damn thing washes out color vibrancy. Also, with an Xbox a CRT monitor refreshes at 60Hz. Some people don't mind this, but I find that long gaming sessions on my Xbox 360 and CRT lead to eyestrains and headaches (because under Windows, the refresh would be higher like 85Hz).
So pretty much there are trade-offs whichever way you go.
There are a couple choices out there. The 23'' Samsung LCD TV is $750 right now at Amazon, which is still too high for me but is a good deal less than what it retails for.
I personally want something that'll function as both a PC monitor and as something to play the 360 on and also be relatively easy to bring back and forth from home and the dorm (i.e. not a FW-900). The one model I've been eyeing is the Syntax Olevia LT26HVX:
http://secure.syntaxgroups.com/products/detail.jsp?pid=LT26HVX
It's gotten a bunch of positive reviews online and is dirt-cheap considering its size and specs. It was on sale a week or two ago at Buy.com for ~$590, but I'm waiting until it hits about $500 to pull the trigger. An LCD TV with a ~8ms response time would be a good solution to what you want.
You might want to go to your local CompUSA and check out the Syntax Olevia 26HVE. They're selling it this week for $500 after rebates. It's a step below the HVX, but I hear it's still a very solid HDTV.
