Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Is there an LCD monitor for this price range that supports HD? I want to replace my current 17 LCD with at least a 20+ inch one. I would be using it for my pc and also as my primary television. If not how much more do I have to spend?
I just ordered the Gateway FPD2185W this week and it does have component inputs for HD. On the gateway.com website and at bestbuy it's listed at $599. Try haggling a little and you might save a few bucks. Also, if you do decide to go with the gateway, just know it doesn't come with the dvi cable.
edit: I believe I read somewhere that there might be an upcoming bestbuy 10% off coupon
