It's pretty well known that if you set the digital volume to less than 100% you might not be getting 16 bits of resolution, and you might have less dynamic range. I'm about to receive a sound card in the mail, so I was looking up inline volume controls, and I found the Koss VC20, but then I read the reviews and some reviewers said that it would have an uneven effect on the final output sound, and it would lower the the highs relative to the other frequencies. This is a problem, and it might not be exclusive to the VC20.
So what inline volume control do you guys use? I'm not looking for anything extravagant, just something that will do the job right. Thank you.
