Chaballaman
- Jun 26, 2001
good hsf for xp2500+
i have two xp2500s with stock hsfs. one stock hsf(coolermaster fan, copper base attached) is better than the other one(amd fan, round copper core). i think the cfm, dba are same but copper base heatsink runs cooler. cpu came with copper base can oc higher n needs less voltage but it might be due the the heatsink..
2.2@1.55 (aqyha, copper base) - 44c idel
2.2@1.65 (kqyha, copper core) - 46c idel
2.45@1.75 (aqyha, copper base) - 48c idel
2.0@1.60 (kqyha, copper core) - 44c idel
i like the stock hsf cos they are light n quite n do the job well, but im thinkin of gettin new hsf to replace the copper core hsf. i dont want thermalright cos i can get new xp2500+ n hsf for same money. i dont want somethin heavy or noisy, im happy with my current setup, i had 3 xp2500s b4 n none of them could run 2.2g stable even with zalman 7000a-alcu on 8k3a. could run 2.2g@1.8-1.9v but overheated on load when ambient was high.
anyway i dont mind zalman 7000b-alcu(438g) but i dont want to cut the fittin on hsf to fit on nf7s.
how good are the new gigabyte 3d cooler range? maybe 3d cooler pro(430g) or 3d rocker(490g)
http://www.giga-byte.com/Peripherals/Products/Products_3DCooler_NewProduct_List.htm
http://www.ocworkbench.com/2004/gigabyte/cooler-pro/PCU21-VG-1.htm (similar to coolermaster aero7, bit worse than thermaltake volcano 11+)
http://www.hardcoreware.net/reviews/review-234-1.htm (500g? 14c below stock p4 hsf at load)
globalwin cak-88t looks ok but weight=?
http://www.globalwinusa.com/products/cooling/cak488t.html
http://www.pcstats.com/articleview.cfm?articleID=1300
or coolermaster xdream iii(420g) or vortex dream 7(439g)
http://www.coolermaster.com/?LT=english&Language_s=2&url_place=product_list&p_class=111
edit: dont worry ill prob get gigabyte 3d cooler pro tomorrow.
http://www.legionhardware.com/html/doc.php?id=278
