Good Generic Printer Ink Vendor?
ZzBloopzZ
I have a older Epson Photo Stylus 750 which still works great, but I am out of black ink. They don't even make brand new ink for it anymore. Thus I am forced to buy generic ink.
Does anyone recommend a good place to order Generic printer ink from? Normally they recycle ink cartridges with their generic ink inside. I remember I had bought 5 packs of generic ink for this printer YEARS ago and they worked great but no idea where I got them from now. I know some vendors use cheap ass crap ink while others use some decent ones. Any recommendations would be helpful!
swiftink.com, check heatware.com or deal sites for coupon codes.
abcink.com, check deal sites and actual site for coupon codes.
As a printer technician I can tell you that generic ink and good never go together. I realize you don't have a choice in the matter if you want to use the printer you've got now but as cheap as these things are I'd just buy a new printer and leave it at that.
I can't really invest in a printer at the moment. I rather just get $12 ink and if my printer dies then get a new printer when absolutely needed.
Most personal use printer/photo printers are cheap. You pay more for ink than the printer after a few refills. I do use generic ink but it is mostly for image/text printing, not photos. I don't print much either. I'm usually always next to some short of computer system where I could plug my usb drive in for access to articles or any other data.
Here is a link to vendor I buy from on ebay:
http://stores.ebay.com/inkjetking99_W0QQcolZ4QQdirZ1QQfsubZQ2d33QQftidZ2QQtZkm
Great price and its worth a try. Bought from them twice. I used this on my epson stylus r300. I got this free from work and I still don't want to use branded ink that I only bought maybe twice? My printer still works flawless and it does not create any kind of mess in the cartridge holder. I printed photo with the generic ink before as demos to show to some people and they look fine. I didn't compare them side by side however so I don't know. It might be true that generic ink might not last as long as branded. It doesn't bother me since the things I print get shredded or thrown away sooner or later.
I ended up ordering from swiftink. It has great reviews and some claim it is some of the best quality as far as generic ink goes. Also, has a great score on resellerratings.com.
Will post later on the quality of the ink.
Thanks!
