Good gaming oriented sandybridge review?
BababooeyHTJ
Has anyone gotten around to a good comprehensive gaming oriented review/comparison with sandybridge with none of that low detail, low resolution bs?
These test are more realistic, I wish most sites used 1920x1080 with max settings to show how much of an improvement (if any) one will see from going to a 2600k from say a Q9xxx or Phenom II x4/x6. I took the plunge and will be checking it out myself.
then your running into gpu limitations not cpu ones. defeats the purposes of testing a cpu in gaming.
Really? That must be why I saw close to a 30% improvement in Serious Sam HD and Darkplaces (the only games that I tested) when I overclocked my cpu by 30%. The minimum framerate in quite a few games is effected with cpu speed. What makes you think that the settings in games will only effect the gpu?
Using unrealistic settings like low settings on a high end cpu defeats the purpose of testing imo.
take a look at the thread i started, which lists several early reviews. off the top of my head, the Tech Spot review uses high game settings.
Thanks, I forgot about the HC review which also has some good benchmarks too.
thats what im saying so are you arguing or agreeing with me??
Thats not at all what you said.
Who is gaming on a $300 cpu at a low resolution and low settings? I also don't agree that you won't run into cpu limitations in some games especially with mods on a high end video card.
LOL i was completely backwards in my train of thought when reading this thread and posting.
Of course, everyone knows real gamers play at 1024x768, low settings, 0xAA 0xAF, amirite?
The purpose of using low settings is to take the video card out of the equation.
It is true you don't get an absolute measure of performance, but you do get a relative rating compared to other CPUs.
That first review on BFBC 2 4xAA 16AF, shows less than 1 frame difference between a 1090T and 2600K @ 2560x1600 & 1920x1080.
Same with Supreme Commander. Even the AMD Quad Cores do fine and even AMD Quad Core beats out the 2600k but like I said, by less than 1 frame difference, but that is what resolution is the most popular in todays games and widescreen lcds sold.
So glad I went with the Quad Core I have, and only spent 88.99 on this CPU instead of hundreds. I feel for the gamers who thought differently. That's life.
