Good find? FSP 700W
you can get a Corsair 620w for less than that after rebate from zzf, buy yeah overall the specs aren't bad
FSP Epsilon.. Out of spec ripple with high loads. I wouldn't waste money.
I'm not real big on multiple 12v rails
Give me a PCP&C with a single 60 Amp rail anyday...:)
Lolz.:p Okay, I think I'm on to something here with this one. It compares with the 520HX, right?
Please make the bad man stop. Seriously, don't do it. If you want a Corsair, get the Corsair, but not an ePower. WTF is ePower anyway? SeaSonic and Silverstone would be a much better option than the two you have posted.
Can that be fixed by replacing the output capacitors with larger ones? Or did I waste a whole $8 on an Epsilon-based 500W Antec Basiq?
I have one of these, it works good for what I need and it seems decent. Although, I would not put anything such as this on a high end build.
The 500w FSP BlueStorm II I reviewed that was a Epsilon based unit did very well. So it may be fine off the bat, then again ti may not....since i haven't seen a Basiq yet.
I had one powering a q6600 and, xfx 680 sli mcp, 2 gig ram ,2 500 gig seagates, and a 8800gtx.plus other stuff
I was waiting for my pcpower and cooling 750 quad
The fx700 gln powered it just fine, i dont know if i wat it running oced like i have now, but everyting stock, it seemed just fine
