Good Exhaust Fans.
Linkin Park
Hi, I recently got a WC setup so i took out all of my case fans and everything is fine and dandy till i start playing HL2. After a good hour of playing My case temp(not CPU) is 38 Degrees and thats obviously way too hot. My cpu shouldnt even be that hot on Watercool. So its obvious that i need some good exhaust fans. I have room for 2 80MM fans on the back for exhaust. And i have my radiator in the front as an intake. So what are some High quality Silent/best CFM ratio out there?
ncantador said:
Thermaltake SilentCats 92mm 52CFM at 21db
80mm 32CFM at 21db
I wouldn't trust Thermaltake's numbers, they are known to be misleading.
Some 80mm Panaflo Low-speed fans would work nicely for you.
