Good entry level HDTV?
IceWindus
Hey guys, im looking into getting my own place soon so of course I need my first HDTV ready to go for my soon to be Xbox 360 and PS3. I dont' wanna shell out a ton of cash for one cause im not made outa money unfortuantly. Wal-mart has some screaming deals on this Sanyo TV that looked really good, even better to the Philips HDTV next to it. Better contrast and colors, even after I tweaked the Philips settings.
Whats your opinion on a decent entry level HDTV that won't put me into bankrupcy?
HT28745
28" Wide Screen 16:9 Integrated HDTV (1080i)
Features:
Dual Integrated Digital (ATSC) & Analog (NTSC) Tuners
2 Component, 2 S-Video, 2 A/V Inputs
3-Line Digital Comb Filter
MTS/SAP Stereo Front Surround Sound
» print this page
HT28745
HDTV (High Definition Digital TV)
1080 vertical lines of interlaced scanning (1080i) provide an exceptionally clean and detailed picture. Equipped with both analog (NTSC) and digital (ATSC) tuners to receive DTV off-air (terrestrial) signals.
For additional information on DTV visit http://www.dtv.gov/index.html , or on HDTV visit www.ce.org. They have
A Consumers Guide to the Wonderful World of HDTV
there at http://www.ce.org/shared_files/resources/HDTV_Brochure_Final.pdf.
Off-Air Digital Signals (terrestrial)
An increasing number of TV stations are broadcasting DTV versions of some of their regular programming at the same time as their NTSC broadcasts using different channels assigned to them by the FCC. This unit can receive and decode all 18 ATSC digital television formats. All broadcasters are scheduled to switch to DTV broadcasts by 2006.
Almost all the digital channels can be received using a UHF antenna. Indoor antennas like rabbit ears or bowtie types should work if you are near the broadcast tower. But you will need a proper outdoor antenna if you are located 30-40 miles from the tower. Antenna height and an unobstructed line of sight affect signal reception. Buildings, steeples, towers and other structures taller than four stories within four blocks of your location can mask or deflect signals.
*To see if DTV broadcasts are available in your area check the latest digital broadcast station listings:
http://www.antennaweb.org/aw/welcome.asp
http://www.nab.org/Newsroom/issues/digitaltv/DTVStations.asp
http://www.fcc.gov/mb/video/files/dtvonair.html
Wide-Screen 16:9 Aspect Ratio Flat Picture
The 16:9 ratio Wide-Screen gives the viewer a full picture of movies and broadcasts, rather than a normally cropped picture in the 4:3 ratio.The 16 by 9 format means that you can watch movies the way you would watch them in the theater while the true flat screen reduces reflections from room lights and windows for outstanding clarity and quality images from corner to corner.
2-Sets Component Video Input (Y-Pb-Pr / R-L)
Five -connector input takes advantage of DVD and other high definition signal sources. Video signal is divided into three separate elements; red, blue and luminance( image brightness) with dedicated Audio (R/L) jacks. Superior to both composite and S-video because it delivers a quality picture with great resolution, better color accuracy and less color bleeding.
Separates luminance (y) and chrominance (C) parts of a video signal . Provides high resolution and picture sharpness while eliminating 'dot crawl.' Also offers sharper, clearer, more detail-perfect color picture reproduction.
Scan Velocity Modulation
Controls the scanning speed of the electron beam, creating sharp transitions between the light and dark portions of the picture with crisp edges and outstanding clarity.
Audio/Video Connection Package includes
*Two Sets of Component Input Jacks
*Two S-Video Input Jacks
*Two sets of Video Input Jacks
* Six sets of Audio Input(R/L) Jacks
* One Optical Digital Output Jack
* One set of Analog Audio Output (Fixed-R/L) Jacks
Enjoy a better quality picture and connect more equipment directly to your TV using a variety of A/V Input Jacks. The Component and S-Video Input Jacks are perfect for connecting a DVD player, DSS, or Super-VHS VCR for a high-resolution picture. Connect a stereo system to the Audio Output Jacks for improved sound.
DTV Remote with PIX Shape key
This remote control has a video input selection key to allow the user to select an A/V input source without going to the menu. A "Tuner" key allows instant access to either the digital tuner and analog tuner channels. Other Info, Audio, Caption and Pix Shape keys allow immediate access to these functions and settings.
Picture Shapes
Available options: Normal, Full, Zoom 1 and Zoom 2 will depend on the format of the signal received and chosen aspect ratio.
Pre-set Picture/Sound Selections
Allow you to choose from: Sports, Movies, and News. Your controls are automatically adjusted for the best viewing and listening. Manual adjustments are always possible.
This improved audio system reproduces a true (right/left) high-fidelity sound with reduced noise interference. Front Surround adds to the movie theater-like sound.
Digital Audio Output (PCM and S/P DIF)
Optical connection for advanced Dolby Digital 5.1 (AC-3) stereo systems. Dependent on audio signals received, PCM (Pulse Code Modulation) are digitized analog signals and S/P DIF (Sony /Philips Digital Interchange Format) are true Dolby signals.
Upgraded Feature Package
Includes on-screen info display, XDS Extended Data Service program information, Initial Channel setting for power-on selection, Auto Flesh Tone and Color Enhancer control.
TV Speakers On/Off (accessible in Menu)
Allows viewer option of turning off TV speakers when using home theatre audio equipment.
Standard Features
* Auto Clock automatically checks and resets time from XDS signal from local PBS station.
* V-Guide feature provides Parental Control using the V-chip technology.
* Channel Recall can be used to quickly change between programs or ballgames.
* Auto Channel Programming with Non-Volatile Channel Memory.
* Closed Captioning Capability with exclusive QuikCap Feature.
* On-Screen Menu Displays (Channel Number, Volume and Digital Controls etc.)
* Color and Feature Reset. Clear all the adjustments and reprogram channels.
* Auto Shut-off is a safety feature, if signals are not present. In Video Modes, TV will NOT shut off!
* Sleep Timer (30-180 min). The TV will switch off after you fall asleep.
Technical Specifications
* Digital Scanning Format
1080i
* Picture Resolution
330 lines/antenna input
800 lines/video input
* Television System
NTSC & ATSC
* RF Antenna Input
Analog - (UHF,VHF,CATV )75ohm
Digital - 75 ohm
* Audio Video Input Jacks
2-Component Video, 2-S-Video, 2 Video,
6-(R/L) Audio
* Audio Output Jacks
1-optical digital
1-analog (R/L) fixed
* Sound Amplifier
Built-in 5 W/ch
* Power
120v AC, 60hz
* Power Consumption
140Watts
* Size (W x H x D)
33.8" x 21.4" x 21.2"
* Weight
92.3 lbs.
Wrong forum but yeah that is a very good HDTV for entry level. My brother in law has the 30" version and it is very good. Also, stay FAR away from the ADVENT brand at best buy. It is very bad I bought the 27" for 350 and it was a peice of junk.
psst....you didn't hear this from me...but at a certain BB service center...."I am told"......they are recieving a ton of those brand in a day....a lot of them....the Advent ones.
What about the Prima TVs that Sears has now?? are they good?? im also looking for an entry lvl HDTV
get a front project much better, cheaper than you think, bigger screen, 16:9 and HDTV support are easily attained under 2000 dollars.
the Optoma H31 you can get for 1089 with a 100" screen and free shipping from visual apex
Yeah, but those replacement lamps...ouch. 200+ per. yeeks. :(
Haha $2000, you gotta be kidding me. In a perfect world :p
When I read the title of this thread, that is the exact television I had in mind. I hang around the AV Science Forum and most of the people there just rave about this HDTV. I am a Wal-Mart hater and the only time I ever walked in to the store was to look at this television. It easily beats out the more expensive Philips and other models out there for ~$1000. I'm hearing there is a new version with the same model number, but does not feature HDMI... so watch out. I'm another one to tell you, stay away from ADVENT. Their televisions are complete POS! Go with the Sanyo, you won't be disappointed.
yes 200-400 is right.. but what is that really?
200/12 = 16.67/mnth
30/16.67 = 1.79
are you telling me you cant save 1.79 dollars a day?
hahah.. NOPE!
do some research, i thought it was impossible too.. a good place is projectorcentral.com awesome reviews, comparrisons, etc..
200/12 = 16.67/mnth
30/16.67 = 1.79
if your like me... no
Arkanian said:
Wrong forum.
How is it the wrong forum when next gen consoles are going to support HDTV? I suppose if you used that theory though people could stray way off topic. :confused:
I tend to disagree. This topic should be in the Displays subforum, which is why it's going there.
