Phrik
- Jan 3, 2006
Old setup:
Res - Pump - CPU - Rad120 - Rad240
* Rad120 was positioned at the back, basically all the case heat is hitting that radiator
Result:
New setup:
Res - Pump - CPU - NB - GTX1 - GTX2 - Rad240 - Rad120
*Both radiators are hit with in intake air. Removed HDD cage to put it there
Result:
I don't OC (maybe one day, until I get some first-hand testing on a better PC than mine), so those are the temps at idle. Both pics where temps at idle, close to 30 minutes after boot.
See sig, for complete setup information.
Is that well good enough at no OC ? Will it do also when I start OCing ? Is there more potential to this setup ?
Cheers mates !
Result:
New setup:
Result:
Cheers mates !
