Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If you want one now then you can pick one up for only $30 or so. But if you dont need it now and can wait about 6 more months or so until DVD-RW come down in price then thats a way to go. IMO if you want one now, then you might as well get a cheap LITEON or LG.
If you look for a bit, you can usually pick up a 4x burner for around $70 after a rebate. I purchased an 8X NEC burner for $100 from www.newegg.com . Making backups of your DVD's is very much worth it, especially after the kids destroy your "Finding Nemo" dvd....twice.
