building a pretty high end server. looking at dual intel xeon 3.06 processors. anyone recommend a GOOD motherboard. would like onboard SATA. but doesnt have to have it as i could just get the PCI card.
Depends on what your doing with the system. Intel makes awesome dual processor motherboards for Xeons. However you will not have any overclocking options to speak of.
Asus is also another good manufacturer to look at. As are Tyan and Supermicro. Check their websites and do some research.
Supermicro. Best MP motherboard I've ever used. They do cost a bit, the one I used was a tad over $600, but they are rock solid boards. I'm not sure if they have any models with SATA, but most have SCSI. If you are building a high end server, you probably want SCSI with 15k rpm drives
If you don't need PCI-X go with the PC-DL, it's fairly inexpensive for a mp board, and it even has some limited overclocking options when not running SATA drives.
