Hitokiri Batohsai
- Apr 22, 2003
I am planning to buy a Tt pipe101, wondering what 92mm fan should I get. Something quiet and able to disperse the heat fast. Any suggestions.
Cause they're loud as fook!apHytHiaTe said:Why not a Tornado?![]()
if you want quietness, the only reason you need to know what a tornado is is so you can stay well away from them. a tornado (made by vantec) comes in 80mm/92mm sizes, and has the highest CFM of any DC fan of the respective size. that also comes with the highest noise level too, though.Hitokiri Batohsai said:Whats a tornado?
Looks are one thing, great cooling, and quiteness is better
rogue_jedi said:if you want quietness, the only reason you need to know what a tornado is is so you can stay well away from them. a tornado (made by vantec) comes in 80mm/92mm sizes, and has the highest CFM of any DC fan of the respective size. that also comes with the highest noise level too, though.
the enermax is pretty good (i think) another alternative would be a panaflo l1a/m1a. dunno where you'd get a 92mm one, though. they exist, but i haven't seen them.
Delta.Pooky said:Tornados are made by Sunon and then re-packaged and labeled by Vantec.
_Korruption_ said:Delta.
Both my 80 & 92mm tornados are Sunons.Pooky said:The one I bought has a Sunon label. Maybe they use 2 different manufacturers?
