Good cheap eATX case?
Any suggestions? Building an esxi server and the motherboard ( X7DWN+ ) I want is a full eATX board. Never bought a case this big.
This is the only one I've found local so far:
http://www.memoryexpress.com/Products/MX48657
It seems decent, looking to see if there are other suggestions?
Thanks.
Specs for that board = EE-ATX (vs. EATX you mentioned)
Maybe useless for you, but a quick search for E-ATX cases under $100:
Chenbro SR105 Chassis
http://www.newegg.com/Product/Product.aspx?Item=1N8-000F-00004
Rosewill RISE Black ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147226
Rosewill ARMOR-EVO Gaming E-ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147175
Rosewill THOR V2 Gaming ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
Ahh, Enhanced Extended ATX....oops, missed an E. Thanks for the suggestions. I like the Rosewill ARMOR-EVO but I've never seen that in Canada...wonder if I can get that here too. I'll have to look around, exactly what I'm looking for.
thanks again!
thanks again!
You may need to look at using a "normal" (read E-ATX or ATX) form factor motherboard.
EE-ATX is usually OEM specific use ... ie SuperMicro in this situation.
I don't think an EE-ATX board would mount properly in any of those case I previously listed, though the board may fit in the space.
This case is meant for that board:
SUPERMICRO SuperChassis CSE-745TQ-R800
I can only guess / assume you want this particular board to re-use existing parts(?)
If that is the case, and depending on your needs, look at the more common E-ATX form factor boards from Supermicro (ie X7DWA-N).
You can also look at used Dell PowerEdge 2900 Gen 3 servers on eBay (Canook version) as they use same Socket 771 CPU and FB-DIMM RAM.
Warning: that old equipment = high power bill ....but great space heating abilities :)
If you're going with e-ATX, you might as well get a better case especially since the thermal and airflow will become a issue.
I am in the same boat: as the six core Westmere EP CPUs dropped to ridiculous cheap on eBay I am very interested in building a machine on two of them and that results in a similar format motherboard. That's why I am necro'ing this thread. It seems the Rosewill THOR V2 supports this format: here http://www.vortez.net/index.php?ct=articles&action=file&id=14056 is a 345mm wide board -- and the Supermicro EEATX is as long as the EATX standard which the case claims to support. I believe there's no airflow issue in that monstrosity :) I plan on using Noctua NH-U9S heatsinks to avoid any clearance issues. Since I plan to use 80W CPUs I think this will be fine. I am unhappy how there are no top front intake fans but Mountain Mods has a Triple Bay 12 adapter converting 3 5.25" bays into a 120mm fan and they also sell a mesh fan guard so if push comes to shove I could add two Silverstone FHP141 fans to help the airflow ... a little :p I wish the Scythe Mini Ninja would still be available, it'd be perfect!
