Good Budget overclocking mobo?
0graymic
I have just brought a new E4400 but my mobo is realy bad at overclocking. im looking at getting a new mobo but i have not got much money. i want a good overclocking mobo similar to the ds3 but if possible, less expensive. Any one have any suggestions?
Also if anyone has any expereance with overclocking this CPU, Can you give me any advice or even what speeds you got from what mobo would be helpfull.
Thanks.
so you want something to perform like a $140 mobo but for less money? well what is your budget?
the ds3 is only $115 from the egg. i can't imagine there is a better board in that price range or lower.
I live in the UK and the cheapest i can get a DS3 is £70 + p&p. This is a bit too much unless the DS3 will be a very good overclocker with this CPU.
Biostar965PT is an excellent choice. It doesn't have RAID and no firewire support and no SLi. I use it to OC an E6420 right now.
I have an open box from Newegg with all retail accessories I will let go for $65 shipped.
While were on the topic, what is the differance between the S3 and the DS3? Is the S3 as good an overclocker as the DS3?
