So I've finally found a good way to describe the issue I find most annoying about digital cameras. From this review (dpreview.com):
Now, that's something I find VERY annoying. That 'bloom' in high contrast shots. We do a lot of hiking in woods, and any shots I take that include the tops of trees, you can basically never see the branches for the 'bloom' from the sky behind them.
If I was interested in a camera aiming specifically at resolving this issue, NOT getting a DSLR, what would be the best bet?
As usual you can expect to see occasional highlight clipping in very bright, contrasty conditions - something common to virtually all high pixel count small sensor compacts. These cameras struggle to capture the full tonal range in scenes with a large dynamic range (high contrast, very bright days). Like previous A series models, the A570 IS's problem seems to be a combination of the usual limited dynamic range of such sensors and a fairly steep tone curve, which can lead to quite harshly clipped highlights
In very high contrast scenes with very strong bright colors we also saw some channel clipping and a little bleeding of color (blooming) across very high contrast edges, but it's nothing that's likely to affect prints and was only observed in a couple of shots.
