Good articles on how to overclock a E6600?
Frosteh
I've had an AMD 64 system for a while now and the architecture of both AMD and Intel chips has moved away from the old style (Multiplyer*FSB) the AMD one was a bitch to learn because of the memory divider business. Now I wish to learn the relationships between the terms used with the Core 2 Duo chips.
The E6600 (arriving tomorrow) runs at 2.4Ghz and 1066Mhz FSB, but the ram required is only PC5300 which is 667Mhz although I got some PC5400 which runs at 675Mhz so I can overclock a bit.
So its a multi of 9 (which i hear is locked?) and that would make it 266Mhz*9=2400Mhz
But where does 266Mhz come from, thats the Non-DDR value of the RAM right? But that would make the ram run at 532Mhz not 667, so is even PC5400 overkill?
Also Im assuming the 1066 is the memory speed (non DDR value, 266) but "quad pumped" which is a term I hear floating about a bit for intel CPU's
Any links to articles with nice diagrams to explain how the value for the speeds of the RAM effect the FSB and the total speed of the CPU etc, would be really handy. I'm not a total n00b (yeah right) it's just my last intel system was back when I had a 733Mhz CPU lol.
Thanks.
Also what are expected temps on stock cooler for:
BIOS
Windows (idle)
Under full load
Whats a good maximum for each, I know Pentiums need to run a lot cooler than AMD's
take a look at the site in my site... theres articles there on everything you asked about.
