sitheris
- Jul 30, 2004
What are my options on headphone amps for Senn HD595's. I have a SB Audigy 2 ZS.
Do I even need an amp?
/clueless
/clueless
Mister X said:Budget?![]()
Mister X said:
winston856 said:I'm about to get the PA2V2. Go to www.electric-avenues.com to check it out. It'll run you about $60-65.
It's a real portable amp that improves bass and overall detail and punch of most headphones. It's an amp that gives a 'warmer' sound.
If you're interest in it at all, email Gary. He is Very generous and reasonable. A great guy to deal with!!
sitheris said:That looks like something i would have to build??? I don't think I wanna do that, I just want something I can buy and use right away with no problems
The PA2v2 can be run from the outlet directly, or by 2 AA batteries. Didn't know if you kneow that (I was confused from your post).pettybone said:I'd like to get one but someone said that you would hear a hum if powered using an outlet.
Using batteries there would be no hum. Any truth to that?
It is always a good idea to
keep a pair of rechargeable batteries installed inside the amp,
even if it will be used from the AC adapter most of the time.
This is because the batteries filter the signal from the adapter
and really help to hold the amp's supply voltage constant. This
results in much more quiet operation of the amp. It depends on
the power supply in each person's area too, some places have a
cleaner electrical signal than others.
I prefer to use NiMH rechargeable batteries in the PA2V2.
There are many good brands such as Duracell, Energizer, Sanyo,
and Golden Power (GP). I usually get the ones that are on sale
at the time or priced well. There are also different mAh
ratings. The higher the rating, the longer the amp will last
between charges. The highest rating these days seems to 2500mAh
but anything over 2000mAh should give you around 100 hours of
battery life in the amp.
If the amplifier is kept turned
on then it is alright to leave the AC adapter plugged in all the
time, the batteries will not become overcharged as long as the
amp is turned on. A lot of people do this, they plug the amp in
next to their computer and just leave the amp running 24 hours a
day, 7 days a week.
If you turn the amp off then the adapter should not be left
plugged in for more than about 12 hours, to prevent
overcharging. After 12 hours of charging this will be enough to
make the batteries full. From there they can last in the area of
100 hours at a medium listening level.
