also the corsair 700/800D with all fans installed
I thought the obsidian series had poor air cooling, But it Is awesome at watercooling.
Silverstone FT02, hands down, not a single case out there can compare.period, the end.
Only downside is if you decide to want to watercool something...........then, not so much.
No.
The Silverstone cases cool exceptionally well, But they are not the best.
The lanboy cools better along with a few others.
No.
I'd like a low noise case. Mid to full tower. I'd prefere one with a lot of ekstra space for wires and when/if I have to do some work, I'm not finding it too dificult to see anything because of the cramped up hardware. But I really liked the FT02 one so far.
If you continue to look at the Silverstone cases you want to lean towards either the FT02 or the RV03 as each do some of what you want.
The FT02 has some foam padding on the sidewalls to reduce noise which I believe is not on the Ravens. However, one drawback of the RV02/FT02 is that there isn't as much room as their should be on the back side of the case so it can get cramped with wiring even if you're pretty anal about your wiring. The FT02 is also a larger than mid tower so the size may be an issue for you.
The RV03 is redesigned a bit and has less depth, and is closer to traditional half tower dimensions. It also has way more room on the back for wires. However it isn't as nice in some ways as the FT02 (such as losing the hard drive cage) and I believe it lacks soundproofing so it will be most likely be louder.
"Low noise" is relative but I find my FT02 to be reasonably quiet even with 2x 6950's in it. I have the old case fans (move less air but are quieter) and those barely make any audible noise even on high; all the case noise pretty much comes from the video cards.
My vote goes to the NZXt Phantom, it keeps my dual 480's @ 54 C idle and 80 C after 3 hours of heavy gaming. I play in 1 hour burst, they get up to 72C. When playing Lego universe with my daughter they barely break the 60C range. LoL
Prove it, and show me the "others".
Does the "lanboy" have the room and features of the Silverstone?
The HAF X cools better, Antec dark fleet does, Its just terribly hideous.
The silverstones only feature is 90 degree mobo mounting.
Lets face it the silverstone ft/rv cases cool very well but they are not the best, 1 120mm fan out will never give you the best cpu cooling.
And the nvidia case you where talking about is the nvidia haf case, with the front wind tunnel that will beat the silverstone cases in every way.
Since I've never seen the other cases or read any kind of reviews......OK.
But I would argue there isn't a better case at any cost.....especially noise levels.
The FT02 is just flat out superior in my opinion.
Here's the list I was after: http://www.legitreviews.com/news/7800/
