For the price, a ninja with a fm121 is a option.
But not a particularly good option. The Ninja isn't that great of a heatsink anymore.
If I needed a new cooler I'd get this one 'cause it's very nice. You'd have to hurry though because it is a limited edition.
http://www.xtremesystems.org/Forums/showthread.php?t=201843
Anyone notice that the Xigmatek 1283 and the OCZ Vendetta look... strikingly similar?
Any info on where to buy?
The TRUE is among the best with the best compatability.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=185&products_id=24018
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=185&products_id=20570
If you're looking to overclocking, go for the ThermalRight Ultra-120 Extreme or TRUE for short. Pair up with a 120mm fan it's a beast.
The beast Thermal Compound out there today would be the Arctic Cooling MX-2 or the Tuniq TX-2. I believe both are equivalent with only TX-2 in the lead by 1- 2 degree in some cases. If you have AS5 on hand, use that, no need to go out and buy a tube for a few degree difference unless you're really into that stuff.
Thanks, I am not looking to do any major OCing. I may do some ''fine tuning'' and thats about it. The goal for this system is going to be stability and performance. I was thinking of just picking up a tube of the TX-2 because of the burn in time.
They're made by the same manufacturer IIRC. Only difference is the fin design.
The Kingwin Revolution is also the same unit rebranded.
