Good Affordable Monitors for Eyefinity.
morizuno
I'm lucking for 3 new monitors for an eyefinity set up. I'm planning on spending around 350$ on monitors. I currently have an HP w2338h, but it is bad for eyefinity (1inch thick bezel. Advertised 23", only 20" screen. 1920x1080).
I'm looking for something cheap, but good. lol
My local comp usa carries http://www.compusa.com/applications/SearchTools/item-details.asp?EdpNo=6322008&CatId=1410
It's a awesome price, bit I don't know about only vga and overall quality.
I can buy from pretty much anywhere BBB accredited. :p
probably a better choice to post this in the display section of the forum..
Why dont you just get two more w2338h. That will give you larger screens and higher resolution. For the bezel it probably won't be that bad, your brain will get used to it and will compensate.
Also you can try a google search see if there anyone that has a pic or youtube video of those monitors in eyefinity to give you an idea.
