BillR said:Since your HTT should not exceed 1000 "3" is your magic number. If you can't rum prime at 3 back things (your ram speed) down. Prime is still the best stress test.
In your case 4 will put you over 1000 and "A" buys you nothing speed wise and "B" will become ustable real fast as a rule.
Check out the stickys
SpoogeMonkey said:What Bill is trying to say is, follow the stickied guide , run prime95 small fft's, and keep bumping up htt/fsb until you get an error,lock up, or reboot. Then back down 10-15mhz and its a matter of trial n error to find that sweet spot that is stable/fastest overall.
Basically, if prime95 isnt stressing 310mhz , bump up htt some more.![]()
DaLurker said:Well i ran two instances of prime. One using Small FFT, one using In Place FFT and they both ran overnight fine at 335mhz HTT/FSB. That's stable then?
BillR said:Yup, I'd call that stable, at least math wise. I'd run some other programs, play some games etc. just to check it out a bit more, but it all sounds good at the moment.
Luck![]()
Luck![]()
