InorganicMatter
- Oct 19, 2004
What is a good 120mm fan? I see everyone likes Panasonic's Panaflo fans, but gosh, newegg wants $25 for one! What's a good alternative?
sac_tagg said:I see everyone likes Panasonic's Panaflo fans, but gosh, newegg wants $25 for one! What's a good alternative?
Oh4Sh0 said:panaflo
hahaNetrat33 said:http://www.compusa.com/products/product_info.asp?product_code=318491&pfp=SEARCH
120mm fan
100 cfm
30-32 dBa
schweet
sac_tagg said:I love how people read the message body.
don't laugh many people have tried them and they are GOOD fans.scottatwittenberg said:haha
MAD DOG > *
that's nice.Qwertyman said:don't laugh many people have tried them and they are GOOD fans.
DFI Daishi said:that's nice.
so who are the fans made by?
why is it that i have some trouble believing that sound rating for a 100 CFM unit? what is their testing procedure exactly?
why does someone looking for a case fan, as opposed to something for a rad, need a 100 CFM fan anyway?
i mean really, why not just cut to the chase and reccomend one of these monsters: http://www.sidewindercomputers.com/de12tfexhisp.html
this is just getting too silly. guy needs something with like 50 CFM output tops. the nexus, would probably do the job as wel, if he wants quiet as opposed to top cooling. next up are the panaflo lows, maybe try out the delta 25mm low. low 30s db range, and plenty of air from either of them.
sac_tagg said:Hey, thanks. I'm not specifically looking for LED lights, but that's cool anyways. May I ask a simple quesion though? This fan:
http://www.newegg.com/app/viewproductdesc.asp?description=11-999-113&DEPA=0
Moves more air but is louder than the one you suggested (34dBA instead of 22dBA). Would I notice to difference in noise that much? And also, the Thermaltake fan moves a whopping 78 CFM, while the Cooler-Master moves about 43. Do I REALLY need the 78 that the Tt offers, or will the 43 of the CM be enough? I plan to do a tiny bit of overclocking (maybe a 2.8@3.4) but nothing too extreme.
made by yate loon. thanks, question answered on that point.Qwertyman said:you gotta chill out just check out the silentpcreview forums before you get all pompous. People there have tried the fans and do actually like them. Plus these are from people that do have nexus and yate loons so its a good comparison. I believe it might be made by yate loon which is a great fan maker, i still doubt it can push 100cfm though.
DFI Daishi said:dude, i am a pompous ass, and i know it. i am also unlikely to change in that regard.
i also sometime know what i am talking about, and usually try to keep my comments to the point.
back to the fans, then.
not readily available up here, either as a mad dog, or as a yate loon, so i'm unlikely to take one for a test spin.
now as for that last little bit: your don't regard the manufacturer (or the company that re-branded it) lying about their numbers as being a problem? you think that it is a great fan, that you would reccomend, in spite of that?
maybe the noise levels are reasonable for those who have tried them first hand. however, by the numbers posted, it is overkill in terms of airflow.
why overclock my computer? because it gives me nice and measurable FPS gains in the games that i play.Netrat33 said:...
why overclock your computer? why have more for basically the same price and noise level? Even if it's not 100 cfm, it sure is pushing a lot of air for a reasonable price and same amount of noise and probably better than most. So I dont' see a problem
DFI Daishi said:why overclock my computer? because it gives me nice and measurable FPS gains in the games that i play.
why have more for basicaly the same price level and noise level? well, the same price level, sure. why not? the same noise level, though? if it really is as quiet as the numbers claim, then there is simply no way that it is moving anywhere near as much air as it claims. if it really moves as much air as it claims then there is no way that it is as quiet as it claims.
5000 RPM, 100 CFM and 32 db are not figures that i conceivably see happening all in the same product.
just as an example:
2500 RPM, 104 CFM and 42 db are the numbers for a panaflo H1A 120mm.
if yate loon (or whoever makes the fan) is really doing something so much better than panasonic, delta, sunon and YS tech then props to them, however i am very highly doubtfull.
the problem is that if the fan does not put out what it is speced for, then the company that is selling/marketing it is lying. that is the problem.
i have heard of them, yes.Qwertyman said:well watever or maybe compusa is lying but that still doesn't make the fan a bad purchase. I don't even know how many fans at 120mm could push 100cfm or higher; there's probably a few.
Also, you've never heard of Yate Loon or Nexus?
