Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
papst and panaflo both make good fans. papst prolly the better made and quieter, but more expensive.
it all depends on what you want really. i mean if all you really want is cooling ability and you dont care about noise you can get a delta. if you need air pressure to push air through a heatercore then the panaflo H1A is a good choice. or the panaflo L1A for a quieter solution.
I like the delta fans myself at full speed you get really good airflow and when turned down a little they are not that noisy.
Yeah you can run any fan off a speed controller just be careful not to have too much current on any one control (the delta's draw 2 amps if I remember correctly).
