Gonna upgrade soon... few Qs
RancidWAnnaRIot
EspantaPajaros
I plan to upgrade from a 8500LE to the sapphire 9800pro... i'm question is, how much extra juice can i pull out of this sucker.. i plan to get a VGA silencer with it. I heard i can softmod it to an XT? but it's only 128MB so how can it be an XT when Xt's have 256MB. Also, after the soft mod woulf it be reasonable to overclock the card?
Last, Just for my information.. when overclocking a video card.. should you relax your RAM timings and clock the CPU back to stock speeds?
Thanks
Thanks
Ram timing on video card? never heard of it. When overclocking a video card, i clock it at 95% of what it can possibly be stable at, use ATI tool when testing and overclocking (everyone has their preferences). I believe you can only softmod a 9800pro if it is a r360 core IIRC, correct me if im wrong, then itll pretty much be a 9800XT 128mb, the amount of memory doesnt matter, when flashing tho you need to change one of the files to let the card kno it has 128mb instead of 256, again IIRC
LOL.. no i was talking about RAM timings on system RAM.. see i have my CPU OCed, and my system RAM at tighter than spec timings.. so i was asking that when you overclock a vid card would it be smart to losen the timings back to specs, and clock down the CPU to stock?
Doesnt make a difference, keep it OCed
Rancid if you can get the X800, and get the 9800 pro only if you are playing many DirectX9 games.
I too have the 8500LE and I tried out the 9600XT for about a week. The card was a tiny jump from my 8500LE which based on that experience I consider to still be a decent video card.
The 9xxx series just isn't that big a jump from the 8500 series. X800pro for about $350 will give you more power for the buck.
yea.. i can't spend more than 200 which is about the amount the 9800pro cost..
If all you can spend is $200 just grab a 9800pro and some ramsinks...happy OCing, youll be happy!
i don't think the 8500LE will play D3 too well no? this is the main reason why i want to go up to a 9800pro.. i want to play D3 pretty decent or a bit more than decent.. though i do plan yo play other games.. i'm just saying this is the bar i'm trying to reach
Unless you have problems then it will be very depressing. I would seriously consider saving up and getting an Nvidia or maybe a newer ATI but when I had my 9800 Pro I tried everything from formats to different drivers and my problems wouldnt go away. Good luck though!
D3 will eat your 8500LE, and its immediate family!
The posts I have read all seem to conclude that the only the 256mb version of the 9800pro can be modded to the XT (since it uses not only the same amount, but the same type of ddr2 ram).
I'm using a built by ATI 9800pro and it is using the same core as the XT (the r360) I didn't attept to mod but as you can see from the sig, the overclock isn't bad and its very stable. A word of caution all of the pros have the xt core. Recently manufactured ati built ones do.
I stand corrected, found a link with the information. I think I'll give it a try on my card.
