gonna buy this mini system
dogbyte_13
ok every thing here minus the case is $520 shipped, and i am going with a micro-fly case, should i drop the 3800+ and get the 3500+ and then get 2 gigs of ram? also im not going to overclock(until a later date)
LITE-ON 16X DVD±R DVD Burner Black IDE Model SHW160P6S05 - OEM
Seagate Barracuda 7200.9 ST3160811AS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
SAPPHIRE 100146L Radeon X1600XT 256MB GDDR3 PCI Express x16 CrossFire Supported Video Card - Retail
OCZ Gold Series 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Unbuffered Dual Channel Kit System Memory Model OCZ26671024ELGEGXT-K - OEM
BIOSTAR TFORCE 6100 AM2 Socket AM2 NVIDIA mATX RoHs compliant AMD Motherboard - Retail
AMD Athlon 64 3800+ Orleans 2000MHz HT Socket AM2 Processor Model ADA3800CNBOX - Retail
First you're gonna need a micro atx board. The tforce 6100 will do. The board you have there will not fit in a microfly.
How much are you gonna pay for that video card? I think you should get an nvidia 7600gt for a little more cash. That's from a x1600 owner too. But I got my card for $75 months ago and now there are better alternatives.
To save some cash you can just go to the 3500+ but if I had the cash I would go dual core.
Also I would not go with 2gb of ram unless you get ddr2-800 which is the highest memory that the x2 can support. you might as well not get stuck with 2gb of slower ram.
