Gonna build budget PC, need help
Zeke
Alright, I need to know what high-end celeron overclocks the best, and on what motherboard. I prefer that the motherboard have onboard video and onboard graphics and sound, but these aren't necessary, however sound would be the nicest... Thanks in advance you [H]ardcore ultimate advisers :)
word processing, internet, maybe DVD's, all I need is onboard-sound and onboard-lan, but either of the two is worth it. I tmay be used for some gaming too
What is your budget and what exact parts you need? Mobo, CPU, case, psu, monitor, keyboard, mouse, speakers, etc?
Yeah look at the 2500+'s at newegg.com, they are only 80 bucks! The mobo that I have is an Asus A7N8X-X, it is about 72 bucks. I gurantee that the 2500+ overclocked to 3200+ (very easy to do) will beat the hell out of any celeron for less money.
ok, then my needs are to know what mobo I should buy for the 2500+, and that I need that mobo to have onboard sound and LAN :)
Depending on your budget, if low, you could go for one of the old shuttle sffs with onboard vid and 5.1 sound. Or if you are spending more, maby one of those new zen style ones. Nice and small, would be great for those uses. Can go for extra quieting too.
edit: +lan too
Any of the Asus A7N8X boards would be a great choice. You could always go with the NF7 boards from Abit.
or Epox8rda3+
i was going to get that board with a 2500+, but changed my mind to building a small size computer
For a budget computer go AMD. Their lowend processors best Intel Celerons in all the budget showdown reviews I have seen. Then you can overclock the AMD which will make the AMD even better then the Celeron.
