Goldenorb II
Vakas
Do any of you guys know how to install any of the ThermalTake heatsinks?
I have the Goldenorb II I have gollowed the instructions but it won't fit like that on my AM2 Socket.
It says to mount clips onto the mouting holes but the heatsink is satill too high from the processor no matter how much u tigter it.
I installed it without the clips and screwed it directly onto the socker seemed to have worked fine but for some reason my cpu is not cooling what's going on.
When I put it on the cpu was stuck to the heatsink so why is it not cooling
you probably picked it up from radioshack
go to the thermaltake website and get the updated instructions for the am2
they are the same instrutions it wqon't even cool my cpu the temperature gets too high and systems turs off wots going on.
