Originally posted by CrimandEvil
I guess you haven't been looking because:
http://www.newegg.com/app/viewProdu...t=Go&description=N82E16820145418&searchdepa=0
But I haven't decided between the PC-3500 Geil or the Corsair.
Originally posted by Suki243
i would go with Corsair or kingston
Originally posted by retardedchicken
my geil is doing me good on my NF7-S, but mines only 3200
value series getting 5-3-3-2 is pretty damn awesome IMO, im getting a second stick for some dual channel action soon enough
Originally posted by Silent.Sin
My GeIL platinum PC-3500 CL2(that's 6-3-3-2) sticks aren't doing so well in my NF7-S. I guess I can't rule out that I'm not cooling the northbridge enough, but I can't get the FSB above 215 stable and that's with loose timings, like 9-4-4-2.5. For some reason it doesn't like CAS3.0, and CAS2.0, which it is actually SUPPOSED to be running at won't run worth a poop over ~185.
These are 2x 512MB sticks, granted they aren't from the same batch and they are running in dual channel, I have tested them both individually without getting better results. I can up the voltage to 2.9v if I want, but I'm worried about heat.
I'm running at 200@2.8vDDR 7-3-3-2.5 right now and it's stable, but it's also winter. I've had problems in the past. Has anyone dealt with GeIL's warranty service? I was thinking about getting some new ones or something. I wasn't too worried about it because I don't know how much farther my 2500+ will go and have stuck with one of the sticks for about a year.
Yeah I can get it more stable with 2.9v and lower timings, haven't tried CAS2 in awhile, maybe it's been worn-in a bit. The problem I have is that these sticks are supposed to be able to do 216.5@2.7v at 6-3-3-2, they clearly aren't.
