Going to reinstall WoW, questions about install process
Ragenrok
ok, well im going to start playing WoW again out of sheer bordem and wanted to know if there are any patches I need to download between installs?
I have all the cd's for WoW, BC and I'll be buying WOTLK today but someone said you need to update wow to a certain patch before you cna install BC and wnated to know if this is true? If it is i'll download the manual patch now instead of through blizards mighty :rolleyes: downloader lol
PS: I've never had a proplem with wow being addictive and have always bal;anced it well with my wife/kid so no need for the "run away, dont play again" kind of coments please, thanks
You don't need patches to install TBC but you need to patch TBC 2.0.0 or something like that to 3.0.0 to play without WOTLK. If you get WOTLK and install them all in a row there shouldn't be much left to patch.
If time isn't an issue, download the client of the account management page.
Just install one right after the other and you'll get all the patches released up to the point the CDs were pressed. So if you get WOTLK you'll only have to update to whatever patches they've released since 3.0 went live (I think it's three or four relatively small patches).
yeah
prepare yourself for a good 2hrs of installingif you start from scratch.
Just a tip the blizzard downloader will probably be your fastest method of getting the patches, but it will completely saturate your incoming and outgoing internet connection.
ya, like I will have the cd's/dvd for all 3 versions just wanted to know if there are any patches imbewteen installs I need to worry about.
Also what version of WOTLK does it install? I'd like to download the manual patches now while at work and bring them home on my usb drive and just install, saves time on downloading lol
just install everything, the blizz installer will let you know if there's missing patches...
but technicly you should only require the 3.03 patch for WOTLK and it's like 20mb .
You saved yourself a ton of time since you already have the game discs. You'll only need to download a small patch afterward and you're set.
1) Install classic WoW.
2) Install Burning Crusade.
3) Install Wrath of the Lich King.
4) Start WoW
5) Let Blizzard Downloader update your game.
6) Say goodbye to social life.
The dvd version of wotlk is everythign you only need to install it for a new install. Barrow a copy it from a friend who has that and then use your cd key online to update your account.
If you do the dvd install you then need 2 patches, one for 340 megs and one for 20 megs.
4) Start WoW
7) say hello to hot BE chicks
fixt
ehhhh..... play conan if you really want hot "in-game" chicks, not WoW :p
lol, come on now we all know the only reason we make femal BE chars is to make her run in circles and stare at her ass :p
is there no cd or something you can download to load everything faster than using the downloader? there has to be a faster way. I made a huge mistake of reinstalling WoW on opening weeking of LK and it literally took me 18 hours to complete from start to finish. Those patches kept coming and wouldn't stop! :(
If you have NOTHING installed on your computer and you buy WOTLK, all you need to do is insert the WOTLK DVD and install away. It installs everything you need to play the game minus patch 3.0.2 or patch 3.0.3.
So basically, you don't need to fiddle with installing World of Warcraft, World of Warcraft: The Burning Crusade, and World of Warcraft: Wrath of the Lich King in series by popping in like 10 different discs. Just throw in WOTLK and you're set.
Here's the method:
1. Remove social drivers
2. Reboot
3. Delete identification
4. Reboot
5. Uninstall doors to outside
6. Reboot
7. Install WoW
