after priceing out what would cost for a new replacement 939 motherboard, I am thinking about just getting a new system.
Thanks for the reply, but considering that I could build an ok AM2 system for $250 range I might just have to plan to build a new system.
Such as
ASUS M2N AM2 NVIDIA nForce 430 MCP ATX AMD Motherboard - Retail
Item #: N82E16813131042
$74.99
mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 996527 - Retail
Item #: N82E16820146118
$74.99
AMD Athlon 64 X2 4400+ Brisbane 2.3GHz Socket AM2 Processor Model ADO4400DDBOX - Retail
$84.99
Might do this AMD Athlon 64 X2 4600+ Windsor 2.4GHz Socket AM2 Processor Model ADA4600CUBOX - Retail
Instead of the 4400
Quick question is the ADO model the low power option processors?
So for a semi gaming setup would this be kind of overclocker friendly?
Recomendations for motherboard + memory + processor are accepted, but total price needs to stay under or right at $300 at most. Would like to get a good overclocking motherboard + processor, but for the price range not necessary
Such as
$74.99
$74.99
$84.99
Instead of the 4400
