Going to be my first PC build
vercat
Antec P160 Case
Intel Pentium 4 650 3.4E GHz 2MB
Asus P5AD2-E Premium
Thermalright XP-120 Heatsink
Corsair TWIN2X1024-5300C4 2x512MB XMS2 DDR2 667Mhz
PowerColor Radeon X850XT 256MB VIVO DVI PCI Express
OCZ ModStream 520W w/620W peak load UV Light ATX/BTX/PCIExp SATA
a few silenx 120mm case fans 58cfm
( all the other stuff i allready have )
what do you think? this will be for gaming.
I have always bought Dells, but now i'm going to try and build my own, any suggestion are welcomed, and any sites abuilding would be good too
VERY VERY Nice he is right though if its for gaming go AMD its better and you can save some cash althought a 4000 is way to much IMO get a 3500 ! and the Power supply seems a bit to much of a overkill too
I would just leave it how it is. Its not like your Intel Processor wont play games at all. That is a high end CPU and it will be fine. Games will run great so dont worry about it.
Have fun with your build. :)
If this is a gaming machine, AMD is just beetter, frankly, if you are making a rig that is primarily for games, AMD is a must.
thanks for the input guys
Friendlypirate80 what did you mean by the power supply being overkill?
I hear you, but they way I look at it too is I play games and I am a Gamer, but I do other stuff more....
