going sli with a gts. worth it?
JVC
do you guys think it is worth the trouble, going sli with two 8800s gts?
If you paid a good amount for your 8800GTS maybe you should wait until the last day of your stepup to see if anything better comes out?:)
Now it dont make sense cost VS performance is no good. But about a month after R600 we should see some real price drops then it may be a different story.
SLI is never worth it. You have to buy a better psu, a compliant motherboard, and pay for the same crappy, outdated card twice (presuming you think SLI is a worthy upgrade path). You also have to deal with twice the heat, twice the power consumption, and at least twice the motherboard real estate (4x for stock 2 slotters/ aftermarkets). Most of all, you probably wont be satisfied with the performance boost considering all the cons. Also, the tauted SLI antialiasing feature will actually cut your performance to less than a single card.
