Before I spend $30. on ati's dvi to component adapter, I was wondering will I see a greatly improved video image? Or is it just a slight increase I would not make much of a difference.
Also, can I used regular AV cables to connect my computer (with the DVI adapter) instead of buying the expensive componet video cables? I have so much of the av cable sitting around I would like to use them. Is there a difference between the cables?
