Someone please help me. All of a sudden one day my icons all got white drop shadows. I want them removed and have tryed all the fixes possible and they still wont go away. Its not that big of a deal, but for some reason its driving me crazy. Any ideas?
control panel > system icon > advance tab > click "settings" in the "performance" section > you should now see a new window named "performance options" with the tab "visual effects" selected. now scroll all the way down and you should see the shadow aoption.
Yea definatly tryed that a couple of times. Use drop shadows is unchecked, but they are still there. Also the items are not locked on the desktop. Thanks for the try though, any other suggestions? I really need to get rid of them.
No I havent installed any programs like that. I checked my theme and it said I was using a customized one. So I tryed the basic Windows XP one, and tryed to recostimize it, but still no luck. This is probably so easy to fix, but I dont know what else to do.
