Gruntled Employee
- Apr 5, 2004
I bought a sapphire radeon 9800pro card and windows XP pro for my rig....freshly installed them both then wanted to see what it could do so I installed a demo of far cry, cranked the graphics up and played about a minute then the computer shut down and would not start again...I found it literally melted the PSU
it requires power from the molex connectors and am not sure if it can be hooked with anything else on the same circuit it WAS sharing one with my hard drive and the only other 2 available are hooked to CD burner and DVD player I had a 300PSU and had a spare 300watt psu I am currently using... my rig specs. are:
AMD +1800XP
Gigabyte GA-7vx mobo
1 gig kingston ddr 333
creative SB live platinum w/live drive
Quantum fireball AS 40GB HD
Aopen 12x cd-burner
Pioneer slot-load DVD 104-s
Sapphire Radeon 9800 Pro
300watt psu (ATX) 2 channels
windows XP PRO OS
currently I am not having a problem but I am scared if I try cranking the graphics up I will melt another one, is the 300 watts adequete or should I go to a 400watt or larger yet? and can you get them with more than 2 channels?
AMD +1800XP
Aopen 12x cd-burner
windows XP PRO OS
