Go farther?
Mikesta
Well, First my setup
Asus A7N8X Deluxe
AMD XP 2400+
Kingston DDR400 512MB
Vcore @ 1.75
Clock Speed @ 2255.11MHZ
Bus Speed @ 150.34
According to asus probe my temperatures are @ 41C Load @ 45C
And
Speedfan says my temperatures are @
Temp1 @ 49C Load @ 55C
Temp2 @ 43C
^ Which one of these are my CPU temperatures?
And I was wondering should I push it a bit more, Yes i applied thermal compound about 2 weeks ago when I first o/c'd
Im running a Aero 7 Lite @ full speed.. Should i push it?
Or you think I should wait it out untill i get a new HSF. What is the BEST hsf i can buy for under $50.
