Hi, I am considering gluing a 30mm fan I scavenged to my NB heatsink to improve cooling - anyone know what type of glue I could use that would bond well, be thermally resistant, and not 'melt' the plastic of the fan?
Instead of a thin, rigid glue like cyanoacrylate, you should consider a flexible adhesive that can be removed in the future (e.g. if the fan fails). If it's rubbery, it will provide some vibration isolation as well. You can try a bit of bathtub caulk in the corners of the fan - clear silicone would likely work well. It will definitely stick to the anodized aluminum of the NB - if you've ever tried to remove such stuff from an aluminum shower door, you'd know how well it sticks.
The fan body is likely not going to be sensitive to some of the solvents in many adhesives. Test it first by putting a small amount on the fan body.
Clear silicone would work fairly well... But i'd still get a 2 part gel epxoy. The quick-set 5 minute gel epoxy sold at home depot works wonders for this.
Just a tiny bit on the fan corners and flip it over onto the HSF.
i am normaly lazy and have a hot glue gun handy so a dab of hot glue is what i use. silicone/ RTV sealant or epoxy would work better, i suppose, if your heatsink gets hot enough to melt the hot glue
Get a Double Sided Adhesive or even thin tape. Cut it to your fitting. But the padded one is better and they are pretty strong stuff. I use these on my 120mm fans and sticking them to the side of my case and they stick pretty good. i really have to use a lot of force to pull them out. I'm so happy with this stuff. No Screws.
