Glueing or bonding acrylic
josephunh
Ok, I have a bunch of pieces I have cut to create a box for housing some circuit boards but what have you folks used to bond or glue together acrylic that also remains clear? I have heard of some fluid that is supposed to bond it togteher but dont know where to get it.
http://www.tapplastics.com/shop/product.php?pid=131&
Works great and bonds in seconds.
note: You will also want some of these squeezie bottles to apply it:
http://www.tapplastics.com/shop/product.php?pid=170&
All you do is squeeze the little applicators, dip the needle into the weld on, hold the two pieces of plastic you want together, |_ and run the weld on into the seam. It will flow in, and if the edges of the two plastics were flat and relatively smooth, it can make the seam perfectly clear.
