Glossy Plastic Paint Job
I haven't tryed that exact brand and everything but I have painted my front bezel and with the exception of the fact that I didn't take my time first time thru it worked quite well. Sand down the plastic before you start and you will be fine.
Kewl. What about the look of plastic and metal that are right next to each other? Can you see much difference?
From what I have read and been told, I'm guessing that they both can achieve the same sort of glossy look.
Can that be applied to plastic and achieve the same results?
Yes it can! That PC Workshop article is the one I used to paint my case. The finish on the plastic parts is indistiguishable from the finish on the metal parts.
